  3. Cutting CLINES - 'scalpel'
  • Replies 7
  • Views 7112
archive over 20 years ago
---  SCALPEL  ----
This utility will cut a path through Clines, according to a path you draw.
It is a little different from other cutting utilities, in the fact you are not limited to drawing a box or a closed polygon.
Clines are cut with a 12mil (or 0.3mm) gap, although you can define the width yourself.
After loading, type one of the following:
scalpel
   to draw a path, or
scalpel help
   to see the options
This program is not that complex but it does give a good example of how to control programs with the mouse, among a few other things.
Richard Moffat
PCB CAD Manager
Copyright Allied Telesis Labs (NZ) 2006
Originally posted in cdnusers.org by Richard Moffat
scalpel.il
  • garys
    garys over 15 years ago +1
    How wouldI download the .iL file?
  • garys
  • garys
     I found the file in the original post. Thanks.
