  3. Add text file to allegro database
  • Replies 8
  • Subscribers 163
  • Views 20984
archive over 20 years ago
I searched through but could not find.  Wonder if anyone comes across the skills command to add a text file to allegro database.
Appreciate your help.
Stella
Originally posted in cdnusers.org by ystella
    Hi Mike,
    Thanks for the reply. I know of this allegro command, just that I am checking if this is also available in skills command. Looks like there isn't...
    Stella
    Stella,
    It shouldn't require too much to create a function like this. You would open the file and read it line by line. When you read a line, you then add the text to the database with axlDBCreateText
    Ron.
    Originally posted in cdnusers.org by rong
    Hi Ron,
    Nice to hear from you.  Thanks for the suggestion.  I know of this alternate method, just that because I thought if there is any straight forward way to call in a text file that I am not aware of.
    Stella
