  3. Finish current command before starting new command
  • Replies 7
  • Views 22827
archive over 20 years ago
I wrote a little skill routine. It works but when it is finished, I have to end each other commands with done before being able to call the next one ("Finish current command before starting new command")
If I run other skill routines, when I finish it, this strange behaviour disappears.
So, something in these other routines si needed in the new one to avoid this behaviour.
But in my stop/cancel I have a axlCancel(Finish)EnterFun, an axlClearSelSet but nothing put Allegro back to normal.
I saw that my stop routine set some variables to nil but if I go to skill mode in allegro and display these variables, some are not set like they should be after a stop....
Any help would be greatly appreciated...
Thanks.
Originally posted in cdnusers.org by willbi
  • luanvn81
    luanvn81 over 2 years ago in reply to DE202408202727
    Hello eDave!
    Thank for reply. I have tested code with [unless( axlOKToProceed(), axlShell("done")) ] but the result still can not done current active command. I think There is no other way to "done" current active command except done command by user. My choice is checking axlOKToProceed() before run skill command. Can you suggest me another way?
    Luan
  • DE202408202727
    DE202408202727 over 2 years ago in reply to luanvn81
    Hi Luan. I'm not aware of another way. Like many Cadence commands, a DONE is necessary before continuing.
