  3. Finish current command before starting new command
  • Replies 7
  • Views 22821
archive over 20 years ago
I wrote a little skill routine. It works but when it is finished, I have to end each other commands with done before being able to call the next one ("Finish current command before starting new command")
If I run other skill routines, when I finish it, this strange behaviour disappears.
So, something in these other routines si needed in the new one to avoid this behaviour.
But in my stop/cancel I have a axlCancel(Finish)EnterFun, an axlClearSelSet but nothing put Allegro back to normal.
I saw that my stop routine set some variables to nil but if I go to skill mode in allegro and display these variables, some are not set like they should be after a stop....
Any help would be greatly appreciated...
Thanks.
Originally posted in cdnusers.org by willbi
    axlShell("done") should do the trick. It ends the active command similar like the ESC key
    or entering done in the command window.
    another way would be to enclose your skill code in this if:
    if( axlOKToProceed(t) then
    .. your code
    else
    printf( "E- finish current command first!\n")
    );end-if
    Tobias
    Originally posted in cdnusers.org by tschirmer
    thanks for this. that helps me not to crash Allegro while forgetting to finish the active command by launching my routine.
    But I still have the problem that at the end of my routine, I hhave to "done" all commands to be able to get next one.
    How are you starting the command?
    If you put a procedure that calls axlShell("done") into a command register, then the command is called automatically when starting a new command.
    procedure(MYFinishCommand()
       axlShell("done")
    axlCmdRegister("mycommand" 'MYCommandStart ?doneCmd 'MYFinishCommand ?cancelCmd 'MYFinishCommand)
    This also automatically makes a context menu (Right mouse click) with "Done" and "Cancel" in it.
    Originally posted in cdnusers.org by natebizu
  • luanvn81
    luanvn81 over 2 years ago in reply to archive
    Hi everyone!
    I also have same problem. In my  skill code , I use ?cmdType "general"  mode for pupose use axlShell ("move*******"). How I can finish  current allegro editor command  before run  my skill command by skill?
    I found that The Done callback function is only registered for “interactive” command type.
    Thanks.
    Luan
  • DE202408202727
    DE202408202727 over 2 years ago in reply to luanvn81
    Try:
    unless( axlOKToProceed(), axlShell("done"))
