  3. parameter settings in Artwork Control form - Cadence Al...
  • Replies 7
  • Subscribers 163
  • Views 7542
parameter settings in Artwork Control form - Cadence Allegro
archive over 20 years ago
7/12/2006 8:19 AM  Quote  Reply
Hello experts,
Anybody knows how the function axlfcreate() which takes the list of 13 numbers works?
I want to control the 'offset x' and 'offset y' but I notice that numbers are based on design units. I couldn't find too much details on this function over cdsdoc.
Any help?
Saad.
Originally posted in cdnusers.org by Saad
    Sadd,
    As far as fields 2, 3 and 4 are units and accuracy are driven by the database it is loaded into.
    Here is an example of the defined fields with the database units set to mils at 3 place accuracy:
    Field 2 = -1000000
    Field 3 = -1000000
    Field 4 = 8000
    The results of the fields above would be:
    Field 2 = -1000.000 mils
    Field 3 = -1000.000 mils
    Field 4 = 8.000 mils
    Basically, all you would need to do is drop the decimal point from the resulting values and define the fields in axlfcreate.
    Here is an example of the defined fields with the database units set to MM at 3 place accuracy:
    Field 2 = -25400
    Field 3 = -25400
    Field 4 = 203
    Field 2 = -25.400 mils
    Field 3 = -25.400 mils
    Field 4 = 0.203 mils
    Basically, all you would need to do is drop the decimal point and the leading zero from the resulting values and define the fields in axlfcreate.
    Originally posted in cdnusers.org by mcatramb91
    Thanks mcatramb91,
    Now I understand how this thing work!
    I appreciate help from all.
    Saad.
