  3. parameter settings in Artwork Control form - Cadence Al...
  • Replies 7
  • Subscribers 163
  • Views 7540
parameter settings in Artwork Control form - Cadence Allegro
archive over 20 years ago
7/12/2006 8:19 AM  Quote  Reply
Hello experts,
Anybody knows how the function axlfcreate() which takes the list of 13 numbers works?
I want to control the 'offset x' and 'offset y' but I notice that numbers are based on design units. I couldn't find too much details on this function over cdsdoc.
Any help?
Saad.
Originally posted in cdnusers.org by Saad
    I believe this is what you are looking for:
    Example axlfcreate SKILL Command:
    (axlfcreate "film_name" '(0 0 0 8000000 0 1 0 0 0 0 0 0 0) '("VIA CLASS CLASS/TOP" ))
    Field description after film record name:
    Field 1 = Rotation (0=0 2=90 4=180 6=270)
    Field 2 = X Offset
    Field 3 = Y Offset
    Field 4 = Underfined Line Width (without decimal point)
    Field 5 = Shape Bounding Box
    Field 6 = Plot Mode (1=Positive 0=Negative)
    Field 7 = Film Mirrored (0=Unchecked 1=Checked)
    Field 8 = Full Contact Thermal-Reliefs (0=Unchecked 1=Checked)
    Field 9 = Suppress Unconnected Pads (0=Unchecked 1=Checked)
    Field 10 = Draw Missing Pad Apertures (0=Unchecked 1=Checked)
    Field 11 = Use Aperture Rotation (0=Unchecked 1=Checked)
    Field 12 = Suppress Shape Fill (0=Checked 1=Unchecked)
    Field 13 = Vector Based Pad Behavior (0=Unchecked 1=Checked)
    Hope this helps,
    Mike Catrambone
    UTStarcom, Inc.
    Originally posted in cdnusers.org by mcatramb91
    Hi Mike,
    Thanks a lot for the details. Do you know what is the relation of units and accuracy settings with field 2,3 & 4?
    for mm board I have to multiply field 4 with following decimals:
    accuracy 1 => field2 x 10 , field3 x 10
    accuracy 2 => field2 x 100 , field3 x 100 and field4 x 10
    accuracy 3 => field2 x 1000 , field3 x 1000 and field4 x 100
    accuracy 4 => field2 x 10000 , field3 x 10000 and field4 x 1000
    and for mils I receive fixnum errors (when i convert mm to mils) and seems like values are only taken in mm.
    What I see here is that there is no chance to setup the parameter option specially for field 2 and 3 in mils because the resultant field values exceed the field limits.
    Saad.
    correction:
    > "for mm board I have to multiply field 4 with following decimals:"
    for a mm board I have to multiply fields with following decimals
    here is an artwork automatic film generator according to stackup using views. It analyses etch layers and create a form with films to be created. Some are made in background (those always to be done) and other have to be selected or not.
    It includes a DBunits analyse to define Undefined Line Width according to database units.
    Hope it helps (it is made with our way of work...
    Originally posted in cdnusers.org by willbi
    film_control.il
    Hi Wllbi,
    Thanks for the reference code. Actually we also have a similer artwork add-on in our environment but recently somebody found a bug (it puts false decimal places when design in mils)
    I wanted to know how you handle this situation in mils?
    I see you are also multiplying with factor of 10, 100, ... for different accuracies but what about if the board is in mils?
    Saad.
