  3. SKILL code for extracting padstack information
  • Subscribers 163
  • Views 15682
archive over 20 years ago
Hi, I'm trying to generate a skill program that can extract all the padstack information on all pad layers and drill. I'm using axlDBGetDesign()->padstacks and get the info from the padstack DBID. But using that method cannot extract some info including drill tolerances, multidrill staggered enabled, etc. and when I tried to use Extracta with view "PADDEF" can extract more information than using skill code. But using that extracta method is hard to know the fields in the extracted report.
Can anyone give me some ideas on how to use SKILL to extract all padstack info?
Thanks and best regards,
Vic
Originally posted in cdnusers.org by victsui
    Hi Vic,
    I don't believe that it is possible to get sufficient information without running an extract.
    Let me know if you need some help as I have some code and an extract view file that might help you.
    Cheers, Dave
    Originally posted in cdnusers.org by Dave Elder
