  3. Early termination of program
  • Subscribers 163
  • Views 14831
archive over 20 years ago
Need a simple answer.  How do I terminate and exit a skill program early if a condition is not met?
Stella
Originally posted in cdnusers.org by ystella
    Hi Stella,
    It may be too simple but you can use the return command within a prog loop.
    eg.
    defun( test (a b)
       prog(()
          unless(a == b return(1))
          return(0)
    Cheers, Dave
    Originally posted in cdnusers.org by Dave Elder
    Hi Dave,
    Thanks. I was trying that out yesterday but got the syntax wrong so it did not work. Solved now. Thanks for the help.
    Stella
