  3. Access Host-ID by Skill
  • Replies 11
  • Views 20786
archive over 20 years ago
Hi, Gurus,
Is it possible to access user Host-ID by Skill? I have tried function getShellEnvVar. It seems useless. Thank you for your helps in advance.
BRs,
Sogo Hsu
Originally posted in cdnusers.org by sghsu
    Hi Rajesh,
    Here's how it works:
    system("ipconfig /all > ipdata.txt"); Prints the result of a DOS ipconfig request to a text file (ipdata.txt) in the working folder.
    ;Note that this command is slightly different in the Unix world (use "ifconfig -a").
    p = axlDMOpenFile("TEMP" "ipdata.txt", "r"); Open that file for reading
    while(gets(ln, p); Step through each line of the file ...
    when(index(ln, "Physical Address"); ...Until you reach the Physical Address line
    hostId = cadr(parseString(ln, ":\n")); The hostId is the second "word" in the Physical Address line
    axlDMClose(p); Close the file
    println(hostId); Print the hostId to the console
    Cheers, Dave
    Originally posted in cdnusers.org by Dave Elder
    archive over 19 years ago
    thanks dave.
    Originally posted in cdnusers.org by rajesh
    hi all
    change
    to
    hostId = car( [b] last [/b](parseString(ln, [b]" :\n"[/b]));
    Originally posted in cdnusers.org by hunter
    change
    to
    hostId = car(  last [/b](parseString(ln, " :\n"));
    Posted By hunter on 11/24/2006 3:44 AM
    change
    to
    hostId = car(  last (parseString(ln, " :\n"));
    ;;Then get the physical address thus:
    while(gets(ln, p)
    hostId = car(last(parseString(ln, ":\n")))
    );end when
    );end while
    axlDMClose(p)
    deleteFile("./ipdata.txt");
    println(hostId)
