  3. Access Host-ID by Skill
  • Replies 11
  • Views 20785
archive over 20 years ago
Hi, Gurus,
Is it possible to access user Host-ID by Skill? I have tried function getShellEnvVar. It seems useless. Thank you for your helps in advance.
BRs,
Sogo Hsu
Originally posted in cdnusers.org by sghsu
    Hi Sogo
    You could write the output of ipconfig /all to a text file using a system command. ie.
    system("ipconfig /all > ipdata.txt")
    Then get the physical address thus:
    p = axlDMOpenFile("TEMP" "ipdata.txt", "r")
    while(gets(ln, p)
    when(index(ln, "Physical Address")
    hostId = cadr(parseString(ln, ":\n"))
    axlDMClose(p)
    println(hostId)
    Cheers, Dave
    Originally posted in cdnusers.org by Dave Elder
    Dear Dave,
    I sincerely appreciated your helps very well.
    BRs,
    Sogo Hsu
    Hi Dave,
    how about the command "infile" instead of axlDMOpenFile?
    Originally posted in cdnusers.org by leonlee
    Hi Leon,
    That would work too - but isn't quite as reliable.
    Cheers, Dave
    Hi dave,
    Can you explain step by step how to get the host id i could'nt undrstand this
    "You could write the output of ipconfig /all to a text file using a system command. ie.
    while(gets(ln, p)
    axlDMClose(p)
    println(hostId)"
    Regards
    Rajesh.
    Originally posted in cdnusers.org by rajesh
