  3. Remove item from list
  • Views 22122
archive over 20 years ago
I'm trying to remove some items which both in two lists.
But the remove command doesn't work.
A='(0 1 2 3 4 5 6 7 8 9)
B='(1 3 5 7 9)
C=nil
foreach(item A
             if(member(item B) then
                C=remove(item A)
why the result is C= (0 1 2 3 4 5 6 7 8) not (0 2 4 6 8)?
how the remove works?
Who can help to tell me the reason or share me a right code to make it true~~
Thanks.
Originally posted in cdnusers.org by leonlee
    I got the right result by using [b] copy [/b] and [b] remd [/b]
    B='(1 3 5 7 9)
    C=copy(A)
    foreach(item A
    remd(item C)
    Hi Leon,
    remove is a destructive function so you were correct to use copy.
    Another (faster) method is to use cons, to create a new list, or the slowish following method
    C = setof(item, A, !member(item, B))
    Cheers, Dave
    Originally posted in cdnusers.org by Dave Elder
    Thanks Dave,
    I havn't think of !member,
    At first, I used member(item B)=nil, it doesn't work. Haha~~
    below is what I use, it is very fast and does not go through unnecessary loops if you have duplicates in list A (or if all items in A have already been removed)
    A='(1 2 1 3 1 4 1 5)
    B='(1 3 5)
    procedure(SubstractList(B A)
    let((item)
    while(B && A
    item=car(B)
    B=cdr(B)
    A=remove(item A)
    A
    Note that both lists are modified inside the procedure. This is ok since they are copies.
    If both lists are dbids, then creating another procedure that uses "req" instead of "remove" will be even faster.
    Originally posted in cdnusers.org by natebizu
  • ajni
    ajni over 10 years ago
    remd does not remove the first element , if it is common in both.
    for a case when A='(1 2 3 4 5 6 )
