  3. skill code for working with internal entities via IPC
  • Subscribers 163
  • Views 14462
archive over 20 years ago
Is it possible to take an internal object, write it to a string, store it in an internal program, then re-use that value in
a Skill program?
For example, if I do this:
rc = ddGetObj( "00test1" )
dd:0xacb0168
to get a library reference stored in variable rc, can I write the value of rc to a string and later recall that value (perhaps
storing it in a completely different variable) to access the same library?  In other words, what I would like to do is
something like this:
myIPCwrite( rc )        to save the value of rc to an extneral process
lib1 = myIPCread()    to recall it
Originally posted in cdnusers.org by gry
    I believe you have the wrong forum. I believe ddGetObj is an Skill API used in the IC tool space, this is the SPB Skill forum
    Originally posted in cdnusers.org by fxf
