  3. How to check the mistaken Reference Text location
  • Replies 21
  • Subscribers 166
  • Views 29112
archive over 20 years ago
How to check the mistaken Reference Text location during arranging the silkscreen?
For example, the component R1 is close to R2, but the Text: R1 and Text: R2 have been exchanged their location. But Allegro can't check them out.
How deal with this situation by SKILL or other solution?
Originally posted in cdnusers.org by leonlee
    archive over 19 years ago
    Hi, Dave,
    I have tried the routine you offered. It's useful to my problem. Thanks.
    And I found a problem about the routine:
    It runs successfully in PCB Design Expert , but there are some error in PCB design 220(PCB studio)
    When I click the [b]DRC list[/b] in [b]DRC Browse Form[/b], the function cann't zoom to the target and tell me an error information:
    E- *Error* setq/set: Variable is protected and cannot be assigned to - layerInfo
    Could you help to check it?
    Hi Leon, I don't see that behaviour in 16.0. It possibly arises because the layerInfo variable is protected by another Skill function that you use in your environment. What version of Cadence are you using? Cheers, Dave
    Originally posted in cdnusers.org by Dave Elder
    My Cadence's version is still 15.5.1 s065(v15-5.1-43CF).
    Hi Leon, I have,'t got a copy of that release handy. Try loading the attached file. I have changed the variable name. Cheers, Dave
    autosilkUtils.il
    It's OK now, Yeah~~
