  3. How to check the mistaken Reference Text location
  • Replies 21
  • Subscribers 166
  • Views 29119
archive over 20 years ago
How to check the mistaken Reference Text location during arranging the silkscreen?
For example, the component R1 is close to R2, but the Text: R1 and Text: R2 have been exchanged their location. But Allegro can't check them out.
How deal with this situation by SKILL or other solution?
Originally posted in cdnusers.org by leonlee
    archive over 19 years ago
    Just a comment. I did a quick check and this skill routine launches and appears to work in version 16.0
    I didn't do any extensive testing but didn't encounter any run errors.
    BillZ
    EMA Design Automation
    Originally posted in cdnusers.org by BillZ_EMA
  • dlocke
    dlocke over 17 years ago
    E- *Error* axlGRPDrwInit: argument #1 should be any user-defined (other) type (type template = "otg") - nil
    I had the same error message and  had the "." in the formpath.
    What I found is that adding a ./ to line 129 fixed the problem.
    Changed: formFile = "ASU_temp.form"
    To: formFile = "./ASU_temp.form"
    Works now...
    Maybe the . in the formpath should be ./  ?
  • harishps
    harishps over 17 years ago
    Can u please reload zip file.
     Thanks in advance,
     Harish
  • jch teyssier
    jch teyssier over 17 years ago
     Hi Dave,
     the file is not downloadable any more.
    I use 15.7 and i think this file should be usefull for me.
    I have found a 2005 version on sourcelink. Can you repost or send this new version?
    Thank's,
    Jean-Charles
  • DE202408202727
    DE202408202727 over 17 years ago
    Hi Jean-Charles,
     The latest version is attached.
     Cheers, Dave
    autosilkUtils.il.zip
