  3. PDF write
  • Subscribers 163
  • Views 17247
PDF write
archive over 20 years ago
Hi, everyone?
Is it possible to write PDF format by Skill?
Originally posted in cdnusers.org by janggj
    It would not be easy to generate PDF directly. However I have written a specification sheet generator that uses XSL FOP and SVG graphics. The good part is that it's all free. Take a look at http://xmlgraphics.apache.org/fop/
    I can provide some small examples if you like.
    CHeers, Dave
    Originally posted in cdnusers.org by Dave Elder
    I've written a PDF export tool using PDFlib (exe file which complies a instruction file to a PDF).
    see ftp://download.nvidia.com/downloads/pdf_print/ you can compile the C-file with the free PDFlib sources and use as postprocessor. This way I can plot PDF from ConceptHDL or AllegroPCB.
    Originally posted in cdnusers.org by tschirmer
    archive over 19 years ago
    Posted By tschirmer on 10/23/2006 3:18 AM
    Mr./Ms.tschirmer, please tell me how to complier your program in windows and solarris sparc. Thanks, CHINA Bird
    Originally posted in cdnusers.org by zxpchx
    Thanks Dave.
    Please send some small examples to me.
    E-mail address : janggj@naver.com
    Hi, I have attached a trivial example. Note that you will need to download the fop utility from: http://mirror.utdlug.org/apache/xmlgraphics/fop/ I also see that 0.93 is now available. You should use this - but I haven't tested the sample code on it. Cheers, Dave
    fopEg1.il
