  3. Problems with axlDMDirectoryBrowse
  • Subscribers 163
  • Views 14750
archive over 20 years ago
Hi, I'm trying to use the axlDMDirectoryBrowse command but seem to run into something related to forward and backslash usage. e.g., axlDMDirectoryBrowse("C:\\Cadence" t ?title "Select Directory for output data") But this still gives me a browse dialog in the default directory. Any ideas as to what the correct usage of path is?
Originally posted in cdnusers.org by ejlersen
    Hi Ole,
    I think that you have found a bug with the axlDMDirectoryBrowse command.
    I always use it with "." as the default directory so had never noticed the problem.
    Will you be raising a PCR?
    Cheers, Dave
    Originally posted in cdnusers.org by Dave Elder
    Hi Dave,
    I've already done so.
    Best regards,
    Ole
