  3. etch length-measuring functions
  • Subscribers 163
  • Views 14500
archive over 19 years ago
Greetings all,
In the past I've had need of  getting the length of a trace, whether that trace be a segment (CLINESEG), path (CLINE) or of an entire net. "show elements" on the trace yields the desired value but I want the value to be available within a SKILL routine.  So I wrote my own set of functions to calculate the value for me.  Here they are:
; length-finding utility functions
; written by: Chris Walters
; These functions will find the length of an etch trace
; for a given segment, path, or entire net, respectively
; Revision History
; 2006/12/13 Chris Walters
; Initial release
procedure( cdw_findSegLength( seg_db)
prog((seglength pt1 pt2 pt3 chordlength rradius aangle xproduct)
seglength = 0.0
pt1 = car( seg_db->startEnd)
pt2 = cadr( seg_db->startEnd)
pt1.x = xCoord( pt1)
pt1.y = yCoord( pt1)
pt2.x = xCoord( pt2)
pt2.y = yCoord( pt2)
if( seg_db->objType == "arc" then
pt3 = seg_db->xy
pt3.x = xCoord( pt3)
pt3.y = yCoord( pt3)
chordlength = sqrt( (pt2.x - pt1.x)*(pt2.x - pt1.x) + (pt2.y - pt1.y)*(pt2.y - pt1.y) )
rradius = seg_db->radius
;determine angle formed by pt1 and pt2 with center at rradius
aangle = 2 * asin( chordlength / (2 * rradius)) ; in radians
;determine whether arc is major or minor
xproduct = (pt2.x - pt1.x)*(pt3.y - pt1.y) - (pt3.x - pt1.x)*(pt2.y - pt1.y) ; 2D cross-product
cond(
( !seg_db->isClockwise && xproduct
seglength = (6.283185 - aangle) * rradius
( !seg_db->isClockwise && xproduct >= 0.0 ; minor arc
seglength = aangle * rradius
( seg_db->isClockwise && xproduct
( seg_db->isClockwise && xproduct >= 0.0 ; major arc
);end-cond
else
seglength = sqrt( (pt2.x - pt1.x)*(pt2.x - pt1.x) + (pt2.y - pt1.y)*(pt2.y - pt1.y) )
);end-if
return( seglength)
);end-prog
);end-procedure
procedure( cdw_findPathLength( path_db)
prog(( pathlength)
pathlength = 0.0
foreach( seg_db path_db->segments
pathlength = pathlength + cdw_findSegLength( seg_db)
);end-foreach
return( pathlength)
);end-prog
);end-procedure
procedure( cdw_findNetLength( net_db)
prog(( netlength)
netlength = 0.0
foreach( net_br net_db->branches
foreach( child_db net_br->children
if( child_db->objType == "path" then
netlength = netlength + cdw_findPathLength( child_db)
);end-if
);end-foreach
);end-foreach
return( netlength)
);end-prog
);end-procedure
Merry Christmas!
Chris Walters
local Cadence guru
Originally posted in cdnusers.org by kerchunk
