  3. Routing Angle
  • Replies 14
  • Subscribers 163
  • Views 26641
Routing Angle
archive over 19 years ago
Hi, can we change the routing angle using skill, currently we can change it to "off, 45, 90", is there a setting in allegro that we need to change so we can route signal using other routing angle like "10" thanks
Originally posted in cdnusers.org by aries
    I'm trying to visualise a design with some traces skewed. Do you mean something like the attached?
    Originally posted in cdnusers.org by Dave Elder
    If you manually routed a 'stairstep' trace from point A to point B
    A----
    ------ B
    a routine could then skew the segments from 0/270 to 350/260, yes.
    Your path is now slightly shorter, which might cause other concerns.
    Naturally, more-complex paths would require more-complex code to achieve the goal. Something like a semicircle
    A--------
    B -------
    would require 'breaking' the vertical segment at the midpoint to yield two smaller segments that can
    be skewed, one tilted backwards the other forwards.
    Or maybe we're overcomplicating the problem? If you are routing these special traces manually why not
    simply turn Routing Angle to 'OFF'
    In closing, a routine could be crafted to help you but its complexity would be in direct proportion to the
    complexity of your requirements and would definately require some fine-tuning - this is not something one
    cound crack out in a few hours.
    HTH,
    Chris Walters
    local Cadence guru
    PS - anyone know of a position for a(nother) Cadence guru?
    PSS - apologies for crude ASCII art
    Originally posted in cdnusers.org by kerchunk
    I can think of two ways of doing this. (Neither require skill)
    1. Rotate the entire design 5-10 degrees, route normally (0,45,90), then rotate back.
    2. Create a visual grid rotated the 5-10 degrees (on an artwork layer). Then route with rotation angle off trying to stay parallel to the grid lines.
    Originally posted in cdnusers.org by natebizu
    I still don't think there is currently a simple solution. I doubt that Cadence would seriously consider an "enhancement" that would allow a random line lock. There is a big mathematical difference between 45 and, say, 10 degrees as far as being able to route on grid. They effectively offer this with the "Off" option.
    I suggest the interim solution is to route visually and use Skill to verify the skew of critical traces. This code would be simple. Let me know if we can help.
    Guys,
    thanks for the ideas, I'll try these ones and let you know what will be the outcome
