  3. Routing Angle
  • Replies 14
  • Subscribers 163
  • Views 26640
Routing Angle
archive over 19 years ago
Hi, can we change the routing angle using skill, currently we can change it to "off, 45, 90", is there a setting in allegro that we need to change so we can route signal using other routing angle like "10" thanks
Originally posted in cdnusers.org by aries
    I don't think that is possible. axlSetLineLock only allows 45, 90 or 0 (off).
    What is your application? I may be able to help if I know what you are trying to do.
    Cheers, Dave
    Originally posted in cdnusers.org by Dave Elder
    Dave,
    thanks for the reply, I'm doing layout (Allegro 15.2~15.7), currently we have some issues about the fabrication of our PCB and Differential Signals/High Speed signals (Fiber Weave Mitigation), in order minimize these effects we need to route high speed signals skewed against the fiber weave of our board, or route high speed signals with at least 5~10 degrees routing angle
    thanks
    Well, it''s got me stumped. Ithe only way I can think of to achieve this via Skill is to re-write the route command. Probably not a very desirable solution. Another alternative may be to ask your fabricator to place your boards at an offset to the weave - or use a laminate where this effect has been reduced.
    Sorry I can't be of more help.
    Cheers, Dave
    Could you route these special traces manually (using 0/45/90) then use a SKILL routine to skew them by the desired angle?
    But having the fabricator build the skew directly into the board sounds like the right solution - transparent to the designer and the skew applies to all traces.
    Keep us apprised and Good Luck,
    Chris Walters
    local Cadence guru
    PS - anyone know of a position for a(nother) Cadence guru?
    Originally posted in cdnusers.org by kerchunk
    "Could you route these special traces manually (using 0/45/90) then use a SKILL routine to skew them by the desired angle?" -- i was hoping that somebody can come up on how we could materialze this idea using skill, as for the skewing the board during fabrication may have some problems, especially when the required sigals to be routed with angle are high speed signals only and we are dealing with multi layered boards
    thanks
