  3. axlTriggerSet problem with latest ISR's
  • Subscribers 163
  • Views 797
archive over 19 years ago
Has anyone else had problems with the latest two ISR's for Allegro 15.7? (s058) I get an error "E- Finish current command first." when I run an interactive command after using the axlTriggerSet fuction and open a new design. If you want to verify this, load the attached code and run "itest" in the command window. It may be related to my environment but is not apparent with earlier ISR's. Cheers, Dave
Originally posted in cdnusers.org by Dave Elder
interactiveTest.il
