  3. Pitch distance measure by Skill
  • Views 19871
archive over 19 years ago
Hello All, I can provide to my Skill program some placed BGA RefDes ("U40" for example). How Skill program could measure this BGA balls pitch distance ? Any response appreciated Thanks, Shimon
Originally posted in cdnusers.org by shimon37
    Hi Shimon,
    Try:
    symbol = car(axlSelectByName("REFDES" "U40")); Select the BGA
    axlClearSelSet()
    pins = symbol ->pins; Identify the BGA pins
    minPitch = nil; Declare the minimum pitch variable
    foreach(pin1, pins
    foreach(pin2, remove(pin1, pins)
    pitch = axlDistance(pin1 ->xy, pin2 ->xy); Measure the pin to pin pitch of every pin with every other pin
    minPitch = if(minPitch, min(minPitch, pitch), pitch); Compare pitch with minimum found so far.
    minPitch
    Cheers, Dave
    Originally posted in cdnusers.org by Dave Elder
    Hi Dave, Thank you very much for your response. It works perfectly. Thanks again, Shimon
    archive over 18 years ago
    Hi Dave,
    I am a beginner in SKILL routines. I know how to include a SKILL function in allegro.ilinit and execute it from allegro. But I don't know how to use the SKILL code directly in allegro(like the one you had in this post for reporting the BGA pitch) because it is not in the form of a skill function. I had tried to switch to the skill command window and paste this code in allegro. But it is not working. I know I am missing some thing. Please correct me if I am not going the right direction.
    Please bear with me for deviating from the original subject...
    Thanks in advance,
    Babu
  • DE202408202727
    DE202408202727 over 18 years ago
    Hi Babu,
    Pasting all those lines into the Skill window won't work. The interactive command interpreter will only accept one Skill command at a time - and it must be all on one line.
    In the example you would have to paste each of these lines one by one:
    minPitch = nil
    foreach(pin1, pins foreach(pin2, remove(pin1, pins)
     pitch = axlDistance(pin1 ->xy, pin2 ->xy) minPitch = if(minPitch, min(minPitch, pitch), pitch)))
    minpitch
    Note how the foreach loop must be self-contained on one line.
    I will discuss this issue with Cadence at the next week's CDNlive conference. Other Lisp implementations that I have used do not have this limitation.
    Cheers, Dave
     Hi Dave,
    I got it worked. Thank you for your valuable inputs.
     Babu
