  3. How can I get spacing/physical rule set?
  • Subscribers 163
  • Views 1581
archive over 19 years ago
Hi, everyone?
for example,
    LAYER1 : Line to Line
                   Min Line width
    LAYER2 : Line to Line
                   Min Line width
Originally posted in cdnusers.org by janggj
    The best way I know of is to export a tech file. In pre-16.0 versions you can then read the tech file back in and obtain the contraints. Note that this will not work in 16.0 because tech files are recorded in XML format. A couple of us are working on a solution.
    axlRunBatchDBProgram("techfile" sprintf(nil, "techfile -$ -w %%s %s", techFile))
    p = axlDMOpenFile("ALLEGRO_TECHNOLOGY_FILE", techFile, "r")
    techFileData = cddr(read(p))
    axlDMClose(p)
    Cheers, Dave
    Originally posted in cdnusers.org by Dave Elder
