  3. Problem about axlFormColorize
  • Subscribers 158
  • Views 13819
archive over 18 years ago
Hi, everyone?
When I executed skill code, message is displayed
    (*Error* axlFormColorize: argument #1 should be any user-defined(other) type (type templete = \"otgg\" nil)
Script is
    mainForm = axlFormCreate( gensym() "GUImain.form" '(e outer) 'callback_main nil t)
    axlFormColorize(mainForm "ordering" 'text 'red)
What's problem?
Thanks.
Originally posted in cdnusers.org by janggj
    I just started getting a similar error after loading the latest ISR for 15.7. To get my older code to execute again I had to path the form whenever it was called. Typically when opening the port:
    Form = outfile("my.form" "w")
    became
    Form = outfile("./my.form" "w")
    and when the form is created:
    npf=axlFormCreate( (gensym) "my.form" '(e outer) 'skill_prog_cback t)
    became
    npf=axlFormCreate( (gensym) "./my.form" '(e outer) 'skill_prog_cback t)
    Note the use of the "./".
    Try this in your code and let me know if it works.
    Originally posted in cdnusers.org by CDL
    The problem is not with the axlFormColorize command. Your axlFormCreate command is not creating the form and is returning nil. This is possible if the form file cannot be found in the form path (as CDL suggests) or there is a syntax error in your form file. If the problem is the form file, try pruning it down until you can identify the problem.
    Cheers, Dave
    Originally posted in cdnusers.org by Dave Elder
