  3. axlSelectByProperty
  • Subscribers 163
  • Views 15543
axlSelectByProperty
archive over 19 years ago
I have 4 components with the property PART_NUMBER= AD8362ARU in my design. To select them all at once, there is a skill function, axlSelectByProperty. it works for nets for example: p = axlSelectByProperty("net" LOGICAL_PATH") returns 472 DBIDs. Then, why axlSelectByProperty("compdef" "PART_NUMBER" "AD8362ARU") returns only one DBID not all 4? axlSelectByProperty("compdef" "PART_NUMBER") returns 112 item, axlSelectByProperty("compdef" "PART_NUMBER" "*AD8362ARU*" t) returns only one! Is it a bug? or a bad use...?
Subsidiary question, why carriage return(newline) are not correctly ddisplayed in messages I post in this forum?
Originally posted in cdnusers.org by willbi
    to get the only empty line we see, I have to write
    twice in the message...
    I read the message about formatting code...
    Then newlines must be there....
    willbi
    There is only one "compdef" record (one component definition record) called AD8362ARU. There may be four, or four hundred, "compinst" records (instances of the component) but only one component definition record.
    Originally posted in cdnusers.org by AshCan
    OK, so it's normal that I have only one DBID... with compdef.
    In fact, I copy/paste the last try and then it was compdef.... but with component it should work.
    axlSelectByProperty("component" "PART_NUMBER" "AD8362ARU") returns "nil"!
    What's wrong?
    there is 4 components with the property PART_NUMBER=AD8362ARU....
    I found that with compdef (which returns only one), car(p)->components length is 4!
    So I have my list... thanks.
