  3. find a string in a file
  • Subscribers 163
  • Views 15143
archive over 19 years ago
Hello all again.
I need to parse a big file to find a string. So I open it for reading (infile) and gets each line and compare it to my string... but it takes a quite long time..
Is there a way to fo it faster? Is there a function to find a string in a file...
Thanks.
Originally posted in cdnusers.org by willbi
    I suggest that you do this outside Skill. If using XP, try using the findstr command.
    eg:
    system("findstr Unison c:\\Cadence\\SPB_16.0\\Update.ini") returns 0 if the text is found, 1 if not.
    Cheers, Dave
    Originally posted in cdnusers.org by Dave Elder
    I've found it handy to hand off certain functions such as text parsing to a PERL program from within SKILL and pick up the output from PERL and continue in the SKILL program.
    Originally posted in cdnusers.org by CDL
    Hello all.
    Thanks Dave for your reply. I tried the way you suggest but the problem is that system procedure opens a visible command window under XP each time it is called.
    So it's not convenient.
    In fact, it seems to be long, so I added a form with informations changind according to what the process does and it now seems faster ;-)
