  3. accessing drill figure info from design?
  • Replies 9
  • Subscribers 163
  • Views 20038
archive over 19 years ago
Greetings,
When you steer toward Manufacturing->Drill Customization a spreadsheet-looking form comes up, obviously built using the axlFormGrid* functions.
Anyone know how to access this info directly thru SKILL?  I vaguely remember  it had something to do with axlGetParam but  I might well be wrong.
TIA,
Chris Walters
local Cadence guru
Originally posted in cdnusers.org by kerchunk
    You should note that padstacks may be in axlDBGetDesign()->padstacks that are not used by the
    design. You should always get the list of vias and pins and build the used padstack list from that.
    Originally posted in cdnusers.org by fxf
    Ah, like if someone placed something that used padstack Z, then later deleted the something but the padstack itself remains in the design file. Subtle.
    Thx for the tip!
    Chris Walters
    local Cadence guru
    I run axlPurgePadstacks before I attempt to do anything that looks at ALL the pad stacks. Cheers Dave
    Originally posted in cdnusers.org by Dave Elder
    axlPurgePadstacks('padstacks nil) can also be used before axlDBGetDesign()->padstacks so that this list just
    has padstacks used in the database. You might want to do axlDBRefreshId(axlDBGetDesign()) after the purge call.
