  3. accessing drill figure info from design?
  • Replies 9
  • Subscribers 163
  • Views 20037
archive over 19 years ago
Greetings,
When you steer toward Manufacturing->Drill Customization a spreadsheet-looking form comes up, obviously built using the axlFormGrid* functions.
Anyone know how to access this info directly thru SKILL?  I vaguely remember  it had something to do with axlGetParam but  I might well be wrong.
TIA,
Chris Walters
local Cadence guru
Originally posted in cdnusers.org by kerchunk
    Hi Chris,
    The table looks to be built directly from the drills used in your design.
    You could easily emulate this using the pin/via definition attributes.
    eg. pin ->definition ->drillChar
    Cheers, Dave
    Originally posted in cdnusers.org by Dave Elder
    Hey Dave,
    Ya I could cycle through every pin/via in the design and build up a table but I was hoping for a more elegant solution.
    fxf gave me a clue to do something very similar to this 3 companies and 6 years ago, I just don't recall. Argh.
    fxf you out there?
    Chris Walters
    local Cadence guru
    You could do it via the extracta. I have generated my own drill tables that way - it's much faster than going through each object dbid by dbid. I would be interested in Frank's answer.
    This form builds its table by finding all pins and vias in the design. Remember to set the "invisible" option in the
    axlSetFindFilter. For performance reasons, it uses this list of pins/vias to build a hash (see Skill association tabke) table
    of all padstacks used in the design.
    See example finding all dbids of a type @ /share/pcb/examples/skill/select/ashfindall.il
    Originally posted in cdnusers.org by fxf
    Thanks Dave, fxf for responding.
    I solved the problem by picking off the drillfigure name and character info while iterating over axlDBGetDesign()->padstacks . And boy was the client surprised when we found the list contained some entries not in the manaully-editied drill legend!
    Thx again,
    Chris Walters
    local Cadence guru
