  3. how to change textblock
  • Replies 9
  • Subscribers 163
  • Views 20614
archive over 19 years ago
Hello, I want to change a textblock number(not textblock params) by using skill languages. For example,the number of textblock changes from "1" to "2". How can i do? thanks, kenji
Originally posted in cdnusers.org by kenji
    archive over 18 years ago
    Hi Rajesh,
    1/ Open the first board
    2/ Load the Skill code - load("forum_TextBlocks.il"
    3/ txtBlks = AFn_recordDesignTextBlocks()
    4/ Open the second design
    5/ AFn_restoreTextBlocks(txtBlks)
    Note that you will need to run the Skill commands from the Skill console (Type "set telskill" in your command window)
    Cheers, Dave
    Originally posted in cdnusers.org by Dave Elder
    Hi Dave,
    Thanks for your reply. But the script changes the text block settings where we do it allegro window (setup --> text sizes and provide the text block width,height etc..).
    What exactly i need is similar to "set_refdes.il" this will extract the refdes silkscreen_top and silkscreen_bottom location,orientation,mirrored,etc in a text file and it will be transferred to another board.
    Like that i need to extract the text block defined for each and every component (if the text block size defined for all the components are not unique throughout the board) and transfer to anoter board.
    Rajesh
    Originally posted in cdnusers.org by rajesh
    Rajesh,
    A modified version of ser_refdes.il is available on SourceLink and it does handle textblocks.
    Originally posted in cdnusers.org by rong
    Thanks Rong
    Rajesh.
