  3. how to change textblock
  • Replies 9
  • Subscribers 163
  • Views 20613
archive over 19 years ago
Hello, I want to change a textblock number(not textblock params) by using skill languages. For example,the number of textblock changes from "1" to "2". How can i do? thanks, kenji
Originally posted in cdnusers.org by kenji
    Hi Kenji
    The only way to do this is to delete then re-add the text.
    Here are some clues:
    txtOrient = make_axlTextOrientation(?textBlock "2", ?rotation txtObjId ->rotation ?mirrored txtObjId ->isMirrored, ?justify txtObjId ->justify)
    axlDBCreateText(txtObjId ->text, txtObjId -> xy, txtOrient, txtObjId ->layer, txtObjId ->parent)
    axlDeleteObject(txtObjId)
    Let me know if you need more help.
    Cheers, Dave
    Originally posted in cdnusers.org by Dave Elder
    Thnaks,Dave.
    I will try by the method.If it doesn't go well, it questions again.
    archive over 18 years ago
    Hi Dave,
    I am using the "set_refdes.il" for geting the refdes location orientation and transfer it from one board to another. But i need to get the refdes text block information also and transfer it to another board. Can you please help me.
    Rajesh.
    Originally posted in cdnusers.org by rajesh
    set_refdes.il
    Hi Rajesh, Attached are two routines that I use to record and restore text blocks. Cheers, Dave
    forum_TextBlocks.il
    Hi Dave,
    Thanks for your replay, can i please know the step by step procedure to extract and transfer the text block by using this il file.
    Rajesh
