  3. need tips and examples for reading a text file
  • Subscribers 163
  • Views 18673
archive over 18 years ago
I'm writing some axlSkill that reads the variants.lst file.
The statement xx = infile("variants.lst") opens the file for reading.
The statement gets(s xx) gets the first line written to a string object s.
Now I'm trying to use a getchar call to look at each character of the string and then decide what to do with the line. Specifically I'm looking for strings that start with "(" (for example).
I try getchar(s 1) == "(" hoping for a return value of t. But even though the first character of string s is ( the getchar call returns nil.
I'm guessing there is an easy way to parse a string and I haven't found it.
Help?
Originally posted in cdnusers.org by AshCan
    getchar returns a character not a string so do
    getchar(s 1) == '\(
    also since a paren is special in Skill it needs to be escaped by a backslash, to match a 'd' all you would need is a 'd
    Originally posted in cdnusers.org by fxf
    Some other options:
    1) use substring instead of getchar.
    substring(s 1 1) == "("
    2) convert the getchar result to a string
    get_string(getchar(s 1)) == "("
    Originally posted in cdnusers.org by Randy R.
    Thanks! Another - even more general - question.
    I've got a major brain freeze going here.
    I'm using a while to read a text file (the variants.lst file). In this example I look at the first character of each line and  see if it is an open paren.
         count = 0
         while(xx
             gets(s xx)
             lineno = count++
             if(substring(s 1 1)=="("
                then
                printf("Line #%d starts with a \"(\"\n" lineno)
                else
                printf("Line #%d doesn't start with a \"(\"\n" lineno)
             ); end if
         ); end while
    Problem is that after the last line of the infile is read I get:
    E- *Error* substring:
    argument #1 should be either a string or a symbol (type template = "Sx") - nil
    The last gets statement has returned a string that is nil.
    If I put in an if loop  if(s != nil  after the gets statement the while loop goes forever. How do I evaluate the result of the gets statement before trying to use it?
    See if this works:
    if( xx = infile("variants.lst") ; make sure we can open the file
    then
    count = 0
    while( gets(s xx)
    lineno = count++
    then
    else
    ); end if
    ); end while
    close(xx); close out the input port
    ); end if
