  3. Please help me to check this issue in Skill.
  • Subscribers 163
  • Views 15739
archive over 18 years ago
I am writing one skill code at present that can help us to view the net layer(Select a net and then visible the etch.After select one net and display the result,the program will not stop.it's loop.You can select other nets). It can recover the display view.The etch layer result also will show at the Ministatus form. My problem is that i don't know how to delete the list in the Ministatus form.I know that one function(axlFormListDeleteAll) can be used to delete the list. But when i used it,it will not display the result in the form again. I used while to loop program. The following is some source code. Please help me to check it out. Thanks.
xlCmdRegister( "glnetlayer" 'gl_netLayer ?cmdType "interactive")
;  Define the Main Function
defun(gl_netLayer ()
  let((layers string gl_netlayer_form_file layers_num)
popup = axlUIPopupDefine(nil
           (list  (list "Done" `axlFinishEnterFun)
           (list "Recover" `gl_Recover_visiable)))
 axlUIPopupSet(popup)
    gl_vis=axlVisibleGet()
    gl_netlayer_form_file = "./netlayer.form"
    gl_netlayer_form = outfile(gl_netlayer_form_file "w")
    fprintf(gl_netlayer_form "FILE_TYPE=FORM_DEFN VERSION=2\n")
    fprintf(gl_netlayer_form "FORM \n")
    fprintf(gl_netlayer_form "FIXED\n")
    fprintf(gl_netlayer_form "PORT 36 19\n")
    fprintf(gl_netlayer_form "HEADER \"Net Layers\"\n")
    fprintf(gl_netlayer_form "\n")
    fprintf(gl_netlayer_form "TILE\n")
    fprintf(gl_netlayer_form "TEXT \"Net Layers\n")
    fprintf(gl_netlayer_form "TLOC 2 6\n")
    fprintf(gl_netlayer_form "ENDTEXT\n")
    fprintf(gl_netlayer_form "FIELD \"GL_netlayer\"\n")
    fprintf(gl_netlayer_form "FLOC 2 8\n")
    fprintf(gl_netlayer_form "LIST \"\" 24 6\n")
    fprintf(gl_netlayer_form "ENDFIELD\n")
    fprintf(gl_netlayer_form "ENDTILE\n")
    fprintf(gl_netlayer_form "ENDFORM\n")
    close(gl_netlayer_form)
    axlControlRaise('options)
    gl_netlayer_form=axlMiniStatusLoad( (gensym) gl_netlayer_form_file nil t)
   axlFormDisplay(gl_netlayer_form)
axlSetFindFilter(?enabled list("noall" "nets")
                     ?onButtons list("noall" "nets"))
      while(axlSelect()
    if( net=car(axlGetSelSet())
    then
       layers = nil
      foreach(branch net->branches
        foreach(child branch->children
          when(child->objType=="path"
            unless( member(child->layer layers)
              layers = cons(child->layer layers)
              layers_num=length(layers)
            );unless
          );when
        );foreach
      );foreach
      when( net->name != nil
          axlVisibleDesign(nil)
        foreach(layer layers
          axlFormSetField(gl_netlayer_form "GL_netlayer" layer)
          axlVisibleLayer(layer t)
   );end when
    axlMsgPut(string)
    else
      axlMsgPut( list("No net selected" 0))
    );end if
);end while
   axlClearSelSet()
 );end let
axlClearSelSet()
);end defun
Originally posted in cdnusers.org by GordonL
    I thnk you've posted in the wrong forum - this forum is for Custom IC SKILL issues, whereas your code is for Allegro - so you want one of the PCB fora.
    Originally posted in cdnusers.org by adbeckett
    Hi, Gordon,
    Where is the codes for the form action?
    You can try to add one line:
    axlFormListDeleteAll(gl_netlayer_form "GL_netlayer")
    before the next step :
    Originally posted in cdnusers.org by leonlee
