  3. Creating Mechanical Symbols
  • Subscribers 163
  • Views 16543
archive over 18 years ago
Hi All,
Does anyone have a simple example of skill code that selects data from an Allegro Board file and then writes the selected data to a mechanical symbol...?
Thanks in advance....
JMW
Originally posted in cdnusers.org by jmwilkinson
    I have some code to do this but it's quite extensive.
    What are you trying to do?
    Cheers, Dave
    Originally posted in cdnusers.org by Dave Elder
    Hi Dave,
    Thanks again for the response...
    I want to build a complex BOM chart as a format symbol to be called back in to BRD files...
    JMW
    OK, That's not too hard.
    I will send you some code on Monday. (It's Saturday here)
    Cheers, Dave
    Hi, See the attached script. Note that your design is closed while the format symbol is created - so you should save before running the code. Cheers, Dave
    skillForum_createFormatSym.il
    Hi Dave,
    Looks great... Thanks for your assistance....
    JMW
