  3. Need help running a Skill
  • Replies 8
  • Subscribers 163
  • Views 19382
archive over 18 years ago
I am trying to create a Fabmaster file.  I downloaded the "cds2f.il" skill file and it worked.  I have since been playing with my env file and now it will not work.  It creates the "t.bat" and the "cds2f.txt" but then it stops.  What I figured out so far is the "t.bat" wants to run "Extracta", which requires a brd name, but it cannot find the brd.  Does anyone have any ideas?
Scott
Originally posted in cdnusers.org by rscotts
    I didn't put the double quotes when I typed it in Allegro and still got the error.
    What license do you need to run Skill ? Will it work with Performance Option L ?
    Originally posted in cdnusers.org by LRCohen1961
    If typing this on the Allegro command line do
    skill load("cds2f.il")
    If doing this from a Skill command window or from the allegro.ilinit file do
    load("cds2f.il")
    In Performance L you will only be able to load this at startup via allegro.ilinit
    Originally posted in cdnusers.org by fxf
    Bill Z at EMA got it to work for me. Thanks to all.
