  3. Need help running a Skill
  • Replies 8
  • Subscribers 163
  • Views 19381
archive over 18 years ago
I am trying to create a Fabmaster file.  I downloaded the "cds2f.il" skill file and it worked.  I have since been playing with my env file and now it will not work.  It creates the "t.bat" and the "cds2f.txt" but then it stops.  What I figured out so far is the "t.bat" wants to run "Extracta", which requires a brd name, but it cannot find the brd.  Does anyone have any ideas?
Scott
Originally posted in cdnusers.org by rscotts
    Delete t.bat and run cds2f.il again.
    Originally posted in cdnusers.org by pantheon
    I'm new to Skill and I'm trying to run this same file.
    I have allegro.ilinit and cds2f.il in C:\Cadence\SPB_16.01\share\pcb\etc\skill. In my allegro.ilinit file, I have only one line which reads "load (cds2f.il)" (without the quotes). When I start Allegro, I get an error that reads "E- *Error* load: argument #1 should be a string (type template = "t") - nil".
    Can you guys help me out ?
    Originally posted in cdnusers.org by LRCohen1961
    Try this
    load ("cds2f.il")
    Boma
    Originally posted in cdnusers.org by Boma
    When I type "load ("cds2f.il")", I get an error saying "E- Command not found: load (cds2f.il)".
    My license is for 'Performance option L'. Can I run Skill files ?
    Simply type
    load ("cds2f.il")
    Don't put double qoutes before load command.
    Originally posted in cdnusers.org by amitku
