  3. Extracting Max Height and Area of Symbols
  • Replies 7
  • Views 19989
archive over 18 years ago
I am trying to extract the Area and PACKAGE_HEIGHT_MAX from symbols using the following code... I am recieving an error on s_prop... Can someone lend a hand...?
max = "PACKAGE_HEIGHT_MAX"
; Open each symbol by name
axlOpenDesign(?design shapename ?mode "wf" )
axlClearSelSet()
axlVisibleDesign(nil)
axlVisibleLayer("PACKAGE GEOMETRY/PLACE_BOUND_TOP" t)
axlSetFindFilter(?enabled "shapes" ?onButtons "shapes")
axlAddSelectAll()
lshape = axlGetSelSet()
foreach(shape lshape
   proplist = shape->prop->??
   if( proplist!=nil ;check to make sure there are attached properties.
   then
      foreach( prop proplist ;step through each property
         sprintf(s_prop "%s", prop) ; This format is incorrect...
         if( s_prop == max
         then
            max_height=car(prop->?)
            shp_area = shape->area
         );end if prop max
       );end foreach
      );end if
 );end foreach
JMW
Originally posted in cdnusers.org by jmwilkinson
    I am treating with the height property too, and I want to got the maximum height.
    See my question at next post~~
    Originally posted in cdnusers.org by leonlee
  • satya12
    satya12 over 17 years ago
    I could not able to down load,can you upload once againg in .zip format?
    Satya
