  3. Extracting Max Height and Area of Symbols
  • Replies 7
  • Views 19988
archive over 18 years ago
I am trying to extract the Area and PACKAGE_HEIGHT_MAX from symbols using the following code... I am recieving an error on s_prop... Can someone lend a hand...?
max = "PACKAGE_HEIGHT_MAX"
; Open each symbol by name
axlOpenDesign(?design shapename ?mode "wf" )
axlClearSelSet()
axlVisibleDesign(nil)
axlVisibleLayer("PACKAGE GEOMETRY/PLACE_BOUND_TOP" t)
axlSetFindFilter(?enabled "shapes" ?onButtons "shapes")
axlAddSelectAll()
lshape = axlGetSelSet()
foreach(shape lshape
   proplist = shape->prop->??
   if( proplist!=nil ;check to make sure there are attached properties.
   then
      foreach( prop proplist ;step through each property
         sprintf(s_prop "%s", prop) ; This format is incorrect...
         if( s_prop == max
         then
            max_height=car(prop->?)
            shp_area = shape->area
         );end if prop max
       );end foreach
      );end if
 );end foreach
JMW
Originally posted in cdnusers.org by jmwilkinson
    1) What is the error message on s_prop?
    2) Have you isolated which line the error is occuring on?
    3) Is "prop" evaluating to something other than a string?
    4) The skill doc doesn't show the comma for the sprintf command syntax (but I don't think this is a problem).
    Originally posted in cdnusers.org by Randy R.
    foreach( prop_pair proplist
    prop_key = symbolToString( car( prop_pair))
    prop_val = cadr( prop_pair)
    if( prop_key == "PACKAGE_HEIGHT_MAX" then
    the important thing to know here is properties are stored as key-value pairs within proplist AND
    the key isn't a STRING but rather a symbol so you need to convert it b4 doing the comparison.
    HTH,
    Chris Walters
    local Cadence guru
    Originally posted in cdnusers.org by kerchunk
    several tips;
    1) axlDBGetProperties(shape "allegro") will return a list of name value pairs instead of using shape->prop->??
    - also allows for high-level property filtering
    2) It is more efficient to compare symbols so either define PACKAGE_HEIGHT_MAX as a symbol or convert it to a symbol
    sym = makeSymbol("PACKAGE_HEIGHT_MAX")
    Alternatively a comparision using a symbol: if( prop_key == 'PACKAGE_HEIGHT_MAX
    3) If you are just trying to get a single property value off a dbid then you can do
    value = shape->prop->PACKAGE_HEIGHT_MAX
    if property is not defined then the value is nil
    Originally posted in cdnusers.org by fxf
    Hi All,
    Thanks for the help... Here is a working update... Please provide any further feedback on ways to make this more efficient...
    JMW
    fprintf(outlog "%s read in for area/max_height extraction...\n" shapename)
    axlClearSelSet()
    axlAddSelectAll()
    proplist=axlDBGetProperties(shape)
    then
    foreach(prop_pair proplist ;step through each property
    prop_key=symbolToString(car(prop_pair))
    prop_val=cadr(prop_pair)
    if(prop_key=="PACKAGE_HEIGHT_MAX"
    then
    max_height=atof(car(parseString(prop_val)))/1000
    ;printf("%s\n" max_height)
    poly = car(axlPolyFromDB(shape))
    shp_area = poly->area
    shp_area = shp_area/1000000
    ;printf("%2.3f\n" shp_area)
    );end if prop max
    );end foreach
    );end if
    );end foreach
    curshapename = axlCurrentDesign()
    axlClearSelSet()
    axlVisibleLayer("PIN/TOP" t)
    axlVisibleUpdate(t)
    axlSetFindFilter(?enabled "PINS" ?onButtons "PINS")
    axlAddSelectAll()
    pincnt = axlGetSelSetCount()
    fprintf(sepupdate "%s,%2.3f,%2.3f,%n\n" curshapename shp_area max_height pincnt)
    axlClearSelSet()
    Hi All,
    My apology for the formatting... Here is an attached formatted version...
    JMW
    test1.il
