  3. schematic script
  • Subscribers 163
  • Views 14074
schematic script
archive over 18 years ago
Hello All.
From an Allegro skill routine, I wrote a script for Concept.
I run it but the script, after page 18 stops without any message. The script contains command from page 2 to 74! So it does not treat 19 to 74.
I first tried to use skill into Concept, but I am not fluent with that. I tried to modify the skill given in the sourcelink.cadence.com/.../11135714_cblibex.zip solution, but unsuccesfully.
The script selects all body and paint the to green. Then it looks for "mounted" property and delete them if found.
Why the script replay fails? Some memory stack overflow?... what else?
Thanks in advance.
Originally posted in cdnusers.org by willbi
