  3. How to get the maximum item in a nonnumerical list
  • Replies 8
  • Subscribers 163
  • Views 18211
archive over 18 years ago
I got a package_height_max property list, and converted it to a short list like below:
HeightList = list("1.6 MM" "1.2 MM" "1 MM" "2.4 MM" "1.5 MM"
    "0.55 MM" "0.7 MM" "3.85 MM" "2.6 MM" "0.1 MM"
    "0.8 MM" "2.1 MM" "2.61 MM" "11.75 MM" "11.7 MM"
    "7.25 MM" "1.1 MM" "1.3 MM" "10 MM" "11 MM"
    "1.27 MM" "6 MM" nil "13.5 MM")
How to get the maximum height value?
I can get each height value one by one, but can't treat with a list .
i.e.
car(parseString(nth(1 HeightList))) -->"1.2"
mapcar(lambda( (x) car(parseString(x))) AllHeight)
E- *Error* parseString: argument #1 should be either a string or a symbol (type template = "SS") - nil
Anybody share me the soultion? Thanks.
Originally posted in cdnusers.org by leonlee
    Posted By natebizu on 2/27/2008 8:39 AM
    ;; to get the max keeping the item as a string
    procedure(_myHeightStringSort(x y)
    unless(stringp(x) x="-1")
    unless(stringp(y) y="-1")
    !onep(alphaNumCmp(y x))
    HeightList=sort(HeightList '_myHeightStringSort)
    maxHeightString=car(HeightList)
    ;; to get max as a number
    HeightNumberList=sort(mapcar(lambda((x) if(stringp(x) then atof(x) else -1)) HeightList) 'greaterp)
    maxHeight=car(HeightNumberList)
    OK, It works well too, thanks.
    archive over 17 years ago
    I know this was an old posting but I am having the same issue but am unsure of where to change the List or how to do so. Can you tell me?
     My error:
    Thank you,
    Michelle
  • DE202408202727
    DE202408202727 over 17 years ago
    Try this:
    HeightList = list("1.6 MM" "1.2 MM" "1 INCHES" "2.4 MM")
    result = car(sortcar(mapcar(lambda((x), list(if(stringp(x), axlMKS2UU(x), x), x)), setof(x, HeightList, x)), 'greaterp))
    maxHgtVal = car(result)
    maxHgtStr = cadr(result)
