  3. How to get the maximum item in a nonnumerical list
  • Replies 8
  • Subscribers 163
  • Views 18210
archive over 18 years ago
I got a package_height_max property list, and converted it to a short list like below:
HeightList = list("1.6 MM" "1.2 MM" "1 MM" "2.4 MM" "1.5 MM"
    "0.55 MM" "0.7 MM" "3.85 MM" "2.6 MM" "0.1 MM"
    "0.8 MM" "2.1 MM" "2.61 MM" "11.75 MM" "11.7 MM"
    "7.25 MM" "1.1 MM" "1.3 MM" "10 MM" "11 MM"
    "1.27 MM" "6 MM" nil "13.5 MM")
How to get the maximum height value?
I can get each height value one by one, but can't treat with a list .
i.e.
car(parseString(nth(1 HeightList))) -->"1.2"
mapcar(lambda( (x) car(parseString(x))) AllHeight)
E- *Error* parseString: argument #1 should be either a string or a symbol (type template = "SS") - nil
Anybody share me the soultion? Thanks.
Originally posted in cdnusers.org by leonlee
    To fix an error:
    is:
    mapcar(lambda( (x) car(parseString(x))) HeightList)[b] [/b]
    The forum can support modifying post~~
    The following may help
    HeightList = remove(nil HeightList)
    last(sort(foreach( mapcar x HeightList evalstring(car(parseString(x " "))) )  'lessp))
    Originally posted in cdnusers.org by sagirameshraju
    You are getting the above error because one of theelements in the list is "nil"(last but one)
    So you need to remove the nil as I mentioned in my reply.
    If the length of list important you can replace with "0" (zero) or which ever is convenient for you.
    ;; to get the max keeping the item as a string
    procedure(_myHeightStringSort(x y)
    unless(stringp(x) x="-1")
    unless(stringp(y) y="-1")
    !onep(alphaNumCmp(y x))
    HeightList=sort(HeightList '_myHeightStringSort)
    maxHeightString=car(HeightList)
    ;; to get max as a number
    HeightNumberList=sort(mapcar(lambda((x) if(stringp(x) then atof(x) else -1)) HeightList) 'greaterp)
    maxHeight=car(HeightNumberList)
    Originally posted in cdnusers.org by natebizu
    Posted By sagirameshraju on 2/27/2008 1:04 AM
    Thanks, it works well.
    HeightValueList=mapcar(lambda( (x) evalstring(car(parseString(x)))) HeightList)
    MaxHeight=apply('max HeightValueList)
    The key function is evalstring, and for maximum value, I use max function.
