  3. Need help
  • Subscribers 163
  • Views 15255
Need help
archive over 18 years ago
Hi All,
Actually i m new to this forum..and skill also...
I m just starting skill programss.....Struck with the following issue...
know that SKILL  trace facility will display the order of evaluation.
But when enter the command "tracef(t) "in the allegro interpreter window
Its showing the following error:
E- *Error* trace: skillDev not enabled.
Can u help me in this to remove the error and move further??.
Ismail.A.
Originally posted in cdnusers.org by ismail
    You must have skillDev license feature.
    and, Type in skill prompt
    Skill > installDebugger
    Skill > load "test.il" --> your skill source code
    Skill > ....
    Thanks..
    Originally posted in cdnusers.org by janggj
    if you have crashing code and want to get an idea what's the cause - try this in your local allegro.ilinit.
    alias( q debugQuit)
    installDebugger()
    sstatus( traceArgs t)
    sstatus( stacktrace 5)
    sstatus( stacktraceDump t)
    uninstallDebugger()
    some sstatus bits cannot be set w/o a SkillDev license. Depending on your available licenses this will not completely work.
    Tobias
    NVidia Germany
    Originally posted in cdnusers.org by tschirmer
