  3. Newbie Questions
  • Subscribers 163
  • Views 14282
Newbie Questions
archive over 18 years ago
I'm having problems getting my first downloaded Skill file to load and run. Can anyone offer some help ? Also, is there a list of available Skill programs that will work with V16.01 ?
Originally posted in cdnusers.org by LRCohen1961
    Load the code into your allegro.ilinit file using load("...../skillFile.il").
    Where "...../skillFile.il". is the path to your file.
    If you put the file in your Skill path you should just have to add load("skillFile.il")
    Most published Skill will run in 16.01. Let the forum know if you find one that doesn't. Someone will fix it.
    Originally posted in cdnusers.org by Dave Elder
