  3. skill routine/function
  • Subscribers 163
  • Views 1739
archive over 18 years ago
Came across a couple of routines that may be skill code but can't find out what tool they run under.  Using Cadence ConceptHDL for schematic capture and AMS Simulator to simulate analog circuits.  The routine of function names are hiGetMultiClickTime() which returns the number in milliseconds between approx. 200 and 1000 that are currently set for mouse clicks.  The other routine is hiSetMultiClickTime(200 to 1000) which allows the user to set the double click mouse time.  What tools do these functions run with?  The functions are not recognized in a cnskill window or console command window.  I don't see the functions in stdAccess.il or any other *.il
files.  I'm running Allegro Project Manager, Allegro Design Entry 15.7 on a Wintel PC (XP Pro OS).
Most skill reference documents do not show the MultiClick routines.  An expert user may know how to implement the functions or similar functions to allow one to set the double click speed in a session.
Originally posted in cdnusers.org by fmacc
    It's not available in Allegro.
    Sourcelink references it in the dfII Virtuoso Design Environment User Guide.
    HTH,
    kerchunk
    Originally posted in cdnusers.org by kerchunk
    kerchunk,
    OK thanks for the info.
    fmacc
