  3. numbered registers and regexp's
  • Subscribers 163
  • Views 1314
archive over 18 years ago
Hey gang,
In Perl matching segments can be captured from a regular expression into special numbered registers:
$refdes = "CA543A"  ;
$1 =~ /\([A-Z]+\)[0-9]+..*/  ;   $1 winds up containing "CA"
The SKILL manual says you can do the same but gives no examples of how to reference the numbered registers. Anyone try this before and/or have some examples?
TIA,
Chris Walters
local Cadence guru
Originally posted in cdnusers.org by kerchunk
    Hi Chris,
    A snippet...
    rexCompile("\\([a-zA-Z]+\\)\\([0-9]+\\)")
    foreach(pin, pins
    pinNumber = pin ->number
    if(rexExecute(pinNumber) then
    loc = pin ->xy, x = car(loc), y = cadr(loc)
    vPin = list(y, rexSubstitute("\\1")), hPin = list(x, rexSubstitute("\\2"))
    Cheers, Dave
    Originally posted in cdnusers.org by Dave Elder
    Thanks for the tip Dave, works like a charm!
    Once again I bow to the power of the almighty List!
    Thx again,
    CASE CLOSED
    Chris Walters
    local Cadence guru
