  3. Hanging code with axlSingleSelectPoint
  • Replies 11
  • Subscribers 163
  • Views 21472
archive over 18 years ago
Hi All,
First skill program...and it almost works.
Initiallly I wrote inline code that did not use a form but prompted the user to enter a point.  It worked, I did a calculation and the code exited cleanly.
Then I added a form (with buttons) but had a dummy callback and again forced the code to run once inline and it worked.
Now I have added a button callback which is working except for the fact that when the code is done executing the status light in the bottom right corner is green but says "Skill" whereas inline it would be "Idle" as expected.
By elimination I can get clean operation (but useless) by eliminating my call to axlSingleSelectPoint.  The code goes merrily on its way and alerts me that I failed to select a valid object and waits for a new button press.  All the while after each button press the indicator goes back to "Idle".
As soon as I re-enable the selectPoint call that piece of code grabs a point, determines what to do and executes with good results but the status is "Skill" at the end of the code execution.  It works repeatably for each button press.
So...what is it about axlSingleSelectPoint that might be causing a callback to hang?
Bill
Originally posted in cdnusers.org by redwire
    Sorry, bad spelling. "Take a look at my attachment" :)
    Hi Bill,
    OK I see what you mean.
    Without all the supporting code (axlFormClose etc.), it's a bit difficult to see what causes the problem.
    Try changing your form to non-blocking:
    myForm = axlFormCreate('formM "xxxx.form" '("SE" "OUTER") 'MyCallBack nil)
    Cheers, Dave
    Originally posted in cdnusers.org by Dave Elder
    Hi again,
    I think you meant to say run in 'blocking' mode as it was in non-blocking. But, ultimately blocking does not provide the intended elegance (tbd, of course) that I am looking for.
    When I finish this cute little program out I should have a form dangling off to the side while I am using Allegro that allows me to do some much desired features.
    If you think of other possible ways to debug this, please let me know.
    Thanks for your efforts so far.
    Bill
    I think it's a bug.
    Place an axlShell("done") command after the axlSubSelectAll() statement.
    Cheers, Dave
    Thanks!!! That works for me.
    Bill
