  3. SPB16 and Tech Files
  • Subscribers 163
  • Views 14596
archive over 18 years ago
Hi All. I was wondering what you are doing regarding the new tech file format in relation to your skill code. Are you having to re-write any code dealing with tech files? Is there a way to export a SPB15 style tech file from SPB16? I just came across this today and I'm not too pleased, heh. Hopefully there is something I am not aware of or overlooking. CJB
Originally posted in cdnusers.org by CJB
    Unfortunately there's not much I can offer other than to tell you the Dave Elder posted a simple skill parser for the Xsection portion of the file. I have had to implement the Xerces parser to digest the XML in my perl code. Unfortunately, I not able to share it. Word from Cadence is that there is no way to export a pre 16.x techfile from 16.x.
    Originally posted in cdnusers.org by cdavies
    In 16 axlGetXSection is a new command which gets you all the cross section information. Maybe you can use that instead of having to create a techfile and traverse that :-)
    Best regards,
    Ole
    Originally posted in cdnusers.org by ejlersen
