  3. Concept-SKILL question: changing default property value...
  • Subscribers 163
  • Views 15102
Concept-SKILL question: changing default property values
archive over 18 years ago
Greetings all,
Working on a routine to change all the refdes values on a schematic.
Tried the csChangePropValue routine inside stdAccess.il  but it turns out
that function only works on custom properties because of its
copy template -> delete property -> create new property using template and new value
method. Turns out Concept won't let you delete a default property like LOCATION.
So, anyone know how to change a default property's value using Concept-SKILL?
TIA,
Chris Walters
local Cadence guru
Originally posted in cdnusers.org by kerchunk
    Steve Durrill, creator of stdAccess.il, was kind enough to respond in a different thread:
    I got a fix from the R&D team a few years ago for
    cnCreateProps() to modify an existing prop object when
    a dbid is provided.
    procedure( chgDefPropVal( h, prop, newVal)
    let(((tplList nil))
    tplList = cons(cnCreatePropTemplate(
    ?name cnGetPropName(prop),
    ?value newVal,
    ?attachXY cnGetPropAttachXY(prop),
    ?XY cnGetPropXY(prop),
    ?color cnGetPropColor(prop),
    ?visibility cnGetPropVisibility(prop),
    ?justification cnGetPropJustification(prop),
    ?size cnGetPropSize(prop),
    ?angle cnGetPropAngle(prop)
    ), tplList)
    cnCreateProps(h, tplList)
    );let
    );procedure
    handle = cnmpsImport()
    props = cnGetProps(cnGetGroupedObjectSet(cnSendCommand(handle, "FINDLOCATION*\n", ?runOptions csDISP1_RES3)))
    p = car(props)
    chgDefPropVal(handle, p, "NEWVALU")
    So there you have it. cnCreateProps will change the value of an existing default property just fine, but function csChangePropValue within stdAccess.il is flawed in that it cannot handle default properties since it tries to delete->replace the property and Concept won't allow deletion of a default property.
    CASE CLOSED
    Chris Walters
    local Cadence guru
    I just took a look at the csChangePropValue() routine.. Since cnCreateProps() accepts DBIDs
    all you have to do to fix the liimitation for default body props is remove this line:
    csDeletePropObjects(handle, propList)
    The new version is included below.
    -Steve
    procedure(
    csChangePropValue(handle, propList, new_value)
    let((tpl_list)
    if(propList then ;; Make sure there are properties to change!
    if(isCallable('cnCreatePropTemplate) then
    ;;Get the template objects with changes included
    tpl_list = foreach(mapcan prop propList ncons(
    csBuildPropTemplate(prop, ?value new_value)))
    cnCreateProps(handle, tpl_list)
    else ;; Release is pre-PE13.5 so call the old routine
    foreach(prop propList
    csChangeProperty(handle, prop, new_value)
    );foreach
    );if
    );if
    );let
    );procedure
    Originally posted in cdnusers.org by sdurrill
