  3. Stand alone skill program that will open different package...
  • Subscribers 163
  • Views 16067
Stand alone skill program that will open different package symbols
archive over 18 years ago
We're considering a package symbol browser and I would like to know if there is any way to start a skill program inside the PCB Editor that will make it possible to open .dra (or show .psm) files one at a time, each time I select a new .dra file then the skill program terminates and I have to start it over again.
Originally posted in cdnusers.org by ejlersen
    Hi Ole,
    This is quite possible and I do it regularly using the axlOpenDesign command.
    Skill continues to work.
    Cheers, Dave
    Originally posted in cdnusers.org by Dave Elder
    Hi Ole,
    You could create a routine that builds a form that contains a FormList object and some Command Buttons like "OPEN", "CLOSE", and "EXIT". You'd then populate the FormList object with a list of all the symbols and display the form. The user would select a symbol from the FormList object then click "OPEN" which in turn calls axlOpenDesign().
    HTH,
    Chris Walters
    local Cadence guru
    Originally posted in cdnusers.org by kerchunk
    Hi Chris and Dave,
    Thanks for your suggestions, I\ll have a look at this.
