  3. From CallBack Function
  • Subscribers 163
  • Views 15677
archive over 18 years ago
Hi All,
I have a questions on the CallBack function for forms
; Here I create my form using the axl skill function  axlFormCreate
MyForm_GlobalHandle = axlFormCreate('MyForm_GlobalHandle        \
                                                               "MyFormName"                    \
        MyFormPosition                  \
                                                               'MyForm_Callback                \
        t                                          \
        nil )
; Later I create the callback function
procedure( MyForm_Callback(TempFormHandle)
  prog( (aaa bbb)
    (printf "aaa = %L\n" aaa)
    (printf "bbb = %L\n" bbb)
When I load the skill function I get an error message that insist there there are 2 variables for my callback function. The only way I can remove this error is to add a " prog ( (aaa bbb) )"  to  have 2 variables for my callback function.
May I know what are there 2 values.  When I printf is out.. the values are always  'nil'
newbie
Originally posted in cdnusers.org by Newbie
    Try calling your form like this:
    MyForm_GlobalHandle = axlFormCreate(gensym() "MyFormName" MyFormPosition 'MyForm_Callback t nil)
    What is the verbatim error message that you receive?
    Cheers, Dave
    Originally posted in cdnusers.org by Dave Elder
    Hi Dave,
    I removed the  prog ( (aaa bbb) ....   from my callback function and changed the axlFormCreate code for 2 cases
    1) MyForm_GlobalHandle = axlFormCreate(MyForm_GlobalHandle() "MyFormName" MyFormPosition 'MyForm_Callback t nil)
    E- *Error* eval: undefined function - MyForm_GlobalHandle
    ERROR
    2) MyForm_GlobalHandle = axlFormCreate('MyForm_GlobalHandle() "MyFormName" MyFormPosition 'MyForm_Callback t nil)
    E- *Error* axlFormCreate: argument #1 should be a symbol (type template = "stlggg") - (MyForm_GlobalHandle)
    ERROR
    Strange thing is that when I tried back the earlier case after removing the prog ( (aaa bbb) ....
    MyForm_GlobalHandle = axlFormCreate('MyForm_GlobalHandle "MyFormName" MyFormPosition 'MyForm_Callback t nil)
    The earlier error I had is gone.
    Anyway Thanks Dave
    You should follow the example @
    /share/pcb/examples/skill/form/basic/axlform.il
    look at function IFormTest.
    The 1st argument to axlFormCreate should be a global symbol. It is used to store the returned formHandle and you can
    use its nil/formhandle value to see if you already have the form opened.
    Originally posted in cdnusers.org by fxf
