  3. Overide a Blocker Function
  • Subscribers 163
  • Views 14494
archive over 18 years ago
Hi All,
1) I want to be able to run a shell command
    axlShell("open")
    to open a new file, but then a dialog comes up asking if I want to save the previous opened file, and this dialog blocks the subsequent skill code until I manually click the buttons.
    Is there anyway to continue running skill code so that I can automatically select "no"?
2) Let say I start an allegro shell function  -> new
    The "new" dialog box comes up and ask for my input for file name.. etc
    Is there anyway I can find out the names of the buttons  e.g.   button_ok, or button_cancel  without having the  .il and .frm file.  I need this to be able to send skill code to choose one of the buttons.
newbie
Originally posted in cdnusers.org by Newbie
    1) Does setting the NOCONFIRM environment variable help? axlSetVariable("NOCONFIRM", t)
    1) This isn't the best way to do this. Use the axlOpenDesign Skill command.
    Cheers, Dave
    Originally posted in cdnusers.org by Dave Elder
    Thanks Dave
    axlOpenDesign( ?design FILENAME ?mode "wf")
    works perfectly!
