  3. axlCompileDesign
  • Subscribers 163
  • Views 14435
axlCompileDesign
archive over 18 years ago
we create DRA file with some information in a special layer for our package symbols.
on this layer we add a frame, with some texts, informations, dimensions, etc...
we save the DRA file with all these informations but we need the PSM to be saved without that.
I wrote a little routine that makes some checks on the dra file, removes the whole documentation layer and then saves the psm.
It works in 15.7 but in 16.01, the axlCompileSymbol fails. There is a database corruption error message.
What I have to add to the skill code to avoid what is shown on the attached file?
Thanks for any help
Originally posted in cdnusers.org by willbi
  • dbdoctor_log.txt
    Do you have a recent Hotfix?
    I run similar functioins in 16.01 without a problem:
    layer = "PACKAGE GEOMETRY/DRAWING_INFO"
    findTypes = '("SHAPES", "LINES", "TEXT")
    axlClearSelSet()
    axlSetFindFilter(?enabled append(list("noall", "invisible"), findTypes), ?onButtons cons("noall", findTypes))
    axlAddSelectAll()
    axlDeleteObject(setof(obj, axlGetSelSet(), obj ->layer == layer))
    axlDeleteObject(axlLayerGet(layer))
    axlCompileSymbol()
    Cheers, Dave
    Originally posted in cdnusers.org by Dave Elder
    I had the S009... but I just installed the latest S010 and everything is in order....
    It also solves a problem I have with 16.01 since the first install, even with the 16.0:
    The swap functions is now fully working! great S010 ;-)
    PS: Thanks for your code. the setof is really nice ;-) I learned something once more today!
